Any suggestions on what the ideal configuration is for a Cerberus x with an Arctic accelero extreme iii? Right now I have the stock triple fan shroud on with two 120mm fans at the bottom of the case and one 120mm fan at the front of the case feeding the gpu fresh air.
Would the Cerberus x be a good candidate to run an exhaust config similar to what I've seen done in ncase m1 setups where the card is deshrouded and put against case fans which are set to exhaust? Curious if anyone has tried a GPU exhaust setup and can compare to intake.
