v5 case arctic accelero fans
NFSxperts
109
51
I have a v5 case with an arctic accelero extreme III. 92cm rear intake fan and exhaust out the bottom.
For those who have the same cooler, which fans are you using at the bottom?
Currently using arctic F12 but I'm hoping for lower temps during the summer.
I've tried Corsair SP120 3000rpms previously but they were too loud at full speed.
I'm considering the corsair ML120 or the Noctua A15, or should I go all out and get the A12x25?
bmacc
24
I’m using two of the new Noctua a12x25 with my Accelero, they are pretty awesome. Move quite a bit of air and are some of the quietest fans I have used, practically inaudible at 1000 RPM and below, not that loud up to 1300 or 1400 RPM.
ps -ef
I am thinking of getting arctic accelero extreme III. May I know what card are you using, and how long is your card with the AAEIII attached?
Thank you.
NFSxperts
109
51
I bought the A12x25s. The stores didn't have it in stock so I had to wait a few weeks.
I run it at 100% to keep it just under 60°C
I'm using at Zotac 1070 mini.
Its about 323mm
