Case Suggestions
eutholevonik
78
72
Hey everyone!
I need help finding a case that will fit in my entertainment system.
Dimensions of the area
D 360mm deep
W 430mm wide
H 317mm tall
Case requirements
2x 3.5 HDDs
2x 2.5 SSDs
Full size GPU
Tower CPU cooler or decent top down
Good airflow
I don't really care about what size the case is, if it supports motherboards bigger then itx, or sfx psu only.
The 2 cases I have found so far that will work are the fractal design core 500 and node 304 but that are little bit too deep. I can get them to fit if I cut part of the entertainment system out.
Wanted to see any other suggestions you guys might have.
Thanks!
eutholevonik
78
72
The Ncase might just work, forgot all about it. Always wanted one but it might be a bit more then I would like to spend on this project.
Thanks for the suggestion!
