Discussion Cannot see external usb hard drive Ubuntu 20.04 X64
lantyforzen
Hello all I'm a newbie.
I have an external usb hard drive and cannot find it anywhere in Ubuntu 20.04 I'm running a dual boot windows 7 and Ubuntu 20.04 the drive is fine in windows but it is not listed anywhere in Ubuntu. I have tried to disconnect it and then reconnect it but no luck. If I plug a usb thumb drive in I get a popup that it is recognized. Any ideas or a starting point? The drive is set up as MBR and formatted as FAT32 Thanks !
This system is old one if the problem is not be solved, maybe I should try other system to running Ubuntu ,how about DFI ?
Freeks
You can check with the 'Disks' application if it is mounted correctly (play/stop icon) but maybe this would be more appropriate in a Linux forum.
Reactions: lantyforzen
BaK
964
956
You can have a look into /media/you_username/ in a terminal if it has already been mounted (unlike Windows, an external disk can be detected correctly but not reachable before it is mounted to a directory)
Code:
ls /media/your_username/
If it is not there, to check if it has been recognized, see if you find it in the list of
Code:
sudo fdisk -l
You should see something like:
Disk /dev/sdb: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Try to find out your disk by its size.
