hi Any1 know this guys buildlog? And where to find it?
S Sebbie Trash Compacter Original poster Apr 5, 2016 47 28 Apr 5, 2016 #1 hi Any1 know this guys buildlog? And where to find it?
jeshikat Jessica. Wayward SFF.n Founder Silver Supporter Feb 22, 2015 4,969 4,783 Apr 5, 2016 #2 I'm almost certain that's a Streacom F1CWS case: http://www.streacom.com/products/f1cws-evo-chassis/ Reactions: janas19
CknSalad Chassis Packer Apr 6, 2016 17 9 Apr 6, 2016 #3 I can confirm with the above poster: http://www.overclock.net/t/1536159/build-log-h2o-micro-sub-3-liter-custom-watercooled-gaming-rig/190 Look for the name TheR3venger
J janas19 SFF Lingo Aficionado Feb 9, 2016 109 39 Apr 6, 2016 #4 Aibohphobia said: I'm almost certain that's a Streacom F1CWS case: http://www.streacom.com/products/f1cws-evo-chassis/ Click to expand... Yep, you can see the small vent holes just above the back I/O for active cooling. And the one small circular hole for your DC power supply. Good eye.
S Sebbie Trash Compacter Original poster Apr 5, 2016 47 28 Apr 6, 2016 #5 Cheers, you guys are right!!
R3venger Trash Compacter Dec 15, 2015 35 44 Apr 8, 2016 #6 Hi, thats my build by the way Reactions: iFreilicht, CknSalad, confusis and 1 other person
CknSalad Chassis Packer Apr 6, 2016 17 9 Apr 8, 2016 #7 R3venger said: Hi, thats my build by the way Click to expand... Did you end up finishing that build? I noticed that you did not have the top cover placed into the case from the pictures you posted on that thread.
R3venger Trash Compacter Dec 15, 2015 35 44 Apr 9, 2016 #8 Na i didnt really finish it, because i had some other work to do. but at the moment im planning something like a DIY Laptop with a thin itx motherboard and a gtx 970 The case is still layin around here Reactions: janas19
