Hello community,
I am currently thinking of building very small build, parts I got:
B760i + 13400 + RAM + SSD + gonna go with either 3050 LP or some ITX card depending on the case (cooler will also be picked depending on the case)
I need advice on the case and power supply used:
PSU - my idea is to use PICO PSU I found one member giving good review - https://www.aliexpress.com/item/1005005377974011.html?spm=a2g0o.cart.0.0.179f38da4UbaKx&mp=1 600W one so that it will stay cool during usage with an internal Mean Well unit - https://www.aliexpress.com/item/1005006602114185.html?spm=a2g0o.cart.0.0.179f38da4UbaKx&mp=1 400W should do the trick I believe.
Will these two go together fine ? or do you have any other recommendation in similar price point ?
Case discussion:
Wanna go as low as possible with volume with 120mm fan cooler (for the noise reasons), was thinking of LZmod A24 v5 https://www.aliexpress.com/item/100...6p1soLW6&utparam-url=scene:search|query_from:
Do you have any similar cases you could recommend me - wanna have some more options![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you.
Case discussion:
Thank you.
