I have reached a point where I need to upgrade my graphics card from the RTX 3060ti and the 3080 seems to be the best in value and performance to match my system. But, the Fractal Ridge case which I really like and need to stick with a slim tower will only allow a 2 slot max graphics card and 20mm/slim fan AIO setup and the Alphacool NexXxoS ST20 HPE is the biggest radiator I can fit.
For all I really use the system for the Shadow Rock LP does just fine on the CPU but I am having fun learning to tweak the whole system, just swapped to a Z690 board so I can undervolt and OC the CPU and it is not enough cooler....
Not sure I can fit any 3 fan units in and have room for the water lines so started looking into a water cooled GPU/CPU setup. With the shorter length of a water cooled GPU I might have room for a small reservoir but might not....
Also I would need to find the best lowest price pump, lines and fittings, just black is fine, no RBG wanted, etc...clear lines OK.
Only did one AIO, CPU only, quite a few years ago so I have somethings to learn about this, more fun
Let me know what you think, know, etc....and Thanks!!!
Rick
Rick
