I am a new comer is this forum. ; )
I want to build a sff PC with water cooling for myself. Indulging in searching for parts which can do more with less volume, i came across a pump-block combo (sorry i don't know if it is so called) for gpu.
https://www.alphacool.com/shop/gpu-...xos-gpx-pro-solo-with-backplate-black?c=20582
The distance between the top and the copper contact is 27.5mm. It covers only the chip. So additional heat sink for the memory is in need. For those who add a radiator with fans in the front of a huge gpu waterblock, this kind of layout seems make more sense, since it helps a lot to reduce the "block" of airflow.
In such tiny chassis are a pump (claimed to be powerful enough for an extra cpu block and radiator) and a block only for gpu, which i think has much better compatibility than the "whole block" (sorry for my lack of words) .
The position of the nozzles seems so suitable for much flexible tubing layout.
