Hi guys, I was wanting to downsize my case a few litres to a Dan Case A4-H20 from a coolermaster NR200. My cpu is a 5800x which is a hard one to tame in the 18L case and i think my current 280mm Artic Liquid Freezer 2 is not really doing the job anymore as temps have just risen 5-8 degrees under a synth load. So I'm trying to work out what my best 240mm AIO options are for such a constrained area. The only tweaking i will do to my CPU is the PBO negative curve, which recently i had to remove due to WZ's coding is causing crashes.
I really like the idea of a 11-12L case and look to put it back up on the desk.
