I am planning on creating a new build and I would love to go sff on this one. I have spent quite a big amount of time and couldn't find any mITX that fulfils my needs, and I would prefer to avoid mATX if I can find a mITX option.
I am looking for the following (must-have):
Option A: mITX
ASUS TUF 3080 should fit horizontally
AIO front or top mounted (if possible 280mm, 240mm at least)
Tempered glass panel or transparent window
Option B: mATX
280mm AIO front or top mounted (240mm if not possible)
Ideally for both options thermals should be decent (this may probably excludes all sandwich layout cases). And if it turns out that only option B is possible, I would love to have a case as small as possible. Finally, this is not a must but a nice to have, would be nice if the case color is either white or silver.
What do you think about this? Any cases out there that I can check?
Option A: mITX
Option B: mATX
