Aby idea takers???
Status
Not open for further replies.
Edward78
233
A Element q or MI-600 (is that it?) <the clone> is good for a change, move the MB tray a little higher to fit a dual width GPU under it, make the ODD a slim one (the ones with a button though) & if you don't want a ODD, just put a rgb strip there, then just make it where any 3.5 i/o panel can go in the cutout...
IntoxicatedPuma
Customizer of Titles
992
1,272
I agree, no need to mod it because you can easily get a slim DVD adapter and use the rest of the 5.25 bay for something else, like a 3.5 hot swap.
No need for dual width GPU when you got the GTX 1070 Katana.
Reactions: AleksandarK
Edward78
233
Cool, you can fit a slim ODD, and a 3.5 something in there (like a 3.5 i/o panel???
Edward78
233
I love the Element Q, but I want a backplate on it with 2 slots, so can put in a dual width gpu???
Edward78
233
Thread title: "Thermaltake Element Q"
Is 1 here in the CAD gallery???
Mod edit: Threads merged
Edward78
233
MOD EDIT: Question about a free EGIS viewer
I have Widows 10...
Edward78
233
MOD EDIT: question about an EGIS file of the Hutzy XS
Edward78
233
MOD Edit: question about a 3D model for the legacy Thermaltake Element Q case from 2010
Anywhere to get it???
Edward78
233
How hard is it to take 1 case that you like the size & replace the MB tray???
7,415
@Edward78 Please keep questions regarding this same case to this thread. We've merged numerous threads here over the past while, not to mention the countless over the past year or two.
jØrd
S̳C̳S̳I̳ ̳f̳o̳r̳ ̳l̳i̳f̳e̳
sudocide.dev
LOSIAS
Jul 19, 2015
818
1,359
Its not that hard at all but no one here is going to do it for you. If your so determined to see this idea to fruition then instead of thread spamming demanding other people do the work for free on your behalf then take the opportunity and time to learn the prerequisite skills needed to do it yourself, much the same way every other case bender, modder and vendor here has done. Its a well walked path and you will likely see much more support looking for help to further your skills and education to bring and idea to life than you will just asking the hive mind to do it for you.
Status
