One thing I dislike most with current PC components is PSU's - They do their job fine, but the two most common form factors, ATX and SFX seem so inefficient... TFX is a nicer one but seems far more uncommon.
ATX and SFX both go for a shape which is quite close to a cube, which doesn't seem to make much sense, unless you mount them on their size, they can be a relatively notably increase to the width of the PC.
I just thought I'd share a set of dimensions I'd come up with quickly in SketchUp, first I'll share an image of an ATX in the space that I was thinking of though.
As you can see, it contributes a fair bit to width, obviously I've not been incredibly tight on clearance, it still fits within parameters I was designing too, but really, it uses up a large amount of width and doesn't make use of reasonable amount of length of the case.
The alternative set of dimensions would be a cross section of 100x75mm with a depth going up to 250 or even 300mm
It then fits far more nicely beneath where the GPU sits. If a concern about aifow existed, well you could put fans on the side.
I wonder what your thoughts are on it?
