Hey fellas,
I've been thinking about this case idea and I just found the time to put together a Sketchup mock-up.
I haven't seen anything like it and it seems perfectly feasible to me but I wanted to share it here to see what you think of it.
In fact with some desirable properties like small footprint and easy-access-to-internals, it might be a winner.
I'll try to insert the 3D model below, let's see if it displays fine:
https://3dwarehouse.sketchup.com/mo...563043fed5d5/Sub-10lt-Full-AIO-Cooling-MockUp
A little more description:
Both motherboard and GPU sides open out with a door on the bottom hinge, providing easy access to internals
Sides, bottom and back is solid, front and top are perforated
Supports GPUs of 2.5 slot width and 300mm length
Recommended cooling config:
Alternative cooling config:
Other alternative cooling configs:
Power switch on the back; HDMI, USB3 1xType-A and 2xType-C on the front
Steel structure and aluminum cover
Approximate dimensions: 125(W) x 210 (D) x 360 (H)
So, what do you make of this?
To be clear, I don't plan to pursue this case idea in the near future, but I'd love to see it materialize somehow. I would especially love it if Aiboh picks it up under the Kimera umbrella (btw, howdy my friend )
- Two 120mm AIO liquid coolers for CPU and GPU
- Negative pressure cooling with two 92x25mm fans and the PSU fan
- A single 240mm radiator for CPU and GPU in a custom or AIO liquid cooling
- Pump+res to be installed on the back
- At most one of the CPU and GPU is liquid cooled (custom or AIO)
- 2 x 120mm fans, or 120mm rad + 120mm fan, or 240mm rad
- Can be converted into positive pressure cooling
- A 3.5" inch drive can be installed instead of 92mm fans on top
- Supports CPU coolers of 65mm height (with 2-slot graphics cards)
