Introduction:
When I joined OCN, I came for the awesome case mods and water cooling builds, but I ended up staying for the SFF builds. However I still enjoy looking at others' watercooling builds, especially in small cases, and miss having one of my own.
So at this moment I'm starting to transition to another scratch built SFF case that can support off-the shelf watercooling parts. Nothing super tiny, no crazy or novel part configurations, just a straightforward case for a mini ITX and most graphics cards. Update: It's now down to 10L, with a vertically mounted GPU that will be visible from a side window panel.
Current design:
Multiple case layout views
The interior layout will be very similar to a NCase M1 but with a tad more vertical room. You see, I had the M1 for a very short while. It's a very well made case, however, I was disappointed when I saw I could not fit my XSPC AX 240 rad on the bottom. First, I needed to remove the front I/O so the cables don't get in the way, and even then I wouldn't be able to fit the slimmest of fans on the rad. And putting it on the side panel wasn't an option for me because I wanted to look through the case to show off the parts inside.
So with that said, my case will also be short and rectangular, like the M1, and also made of aluminum. But I also am inspired by the cases by Sunmilo for their simplicity in looks and craftsmanship. Whereas the M1 is made from precisely machine cut parts (especially the frame), the Sunmilo cases, for the most part, look simple and practical enough to be made by common home tools, and I really like that about them.
First Version:
It is more likely I will finish this case before Slim Machine, which is put on the backburner. I've started to replace some of my PC components to test specifications of the case, such as a full-length GPU, and a 120mm tower CPU cooler.
This build log will be split into two phases: Air and Water. The Air phase is the first, using lower-cost components and showing off the case with an air-cooled system. That will be done on a shoestring budget, a kind of "basic but good" build.
Air Build Parts:
That will be later followed by the Water phase, where I want to go all out and get a high-end CPU and Pascal GPU and watercool the entire thing. That won't start until I have saved enough money for all the parts. For the time being, I just want to make a scratch build I can really show off, no matter what the budget is.
I'll update this post with pics of the first design later on.
Current design:
First Version:
Air Build Parts:
- Asus Z97I-Plus motherboard
- Intel Core i3-4130T
- 2x4GB Samsung low-profile "wonder" RAM
- EVGA GTX 770 Superclocked
- Corsair CX550M semi-modular power supply
- SanDisk X110 128GB m.2 SSD
- Toshiba 3.5" 2TB hard drive
