I'm just starting my A4 v3 build. I took the case out of the box last night and had a look at things.
This will be an air-cooled build and I intend to install a 92mm fan in place of the 2.5" drive tray. Given that the tray is installed using screws through rubber grommets, the holes in the case are a bit bigger than the usual fan screw holes.
- What's the preferred method of attaching a fan here? Just put a fan screw through the grommet?
- Has anyone tried installing a foam filter on the bottom of the case (to minimize dust intake)? It would be nice if the feet were a bit taller for this; but it looks like there's enough clearance.
