Resource icon
Enclosure 486 front panel 1:2 for InWin Chopin 2018-04-29
iPeg
iPeg submitted a new resource:
486 front panel 1:2 for InWin Chopin - Makes a Chopin ITX case look like a tiny oldschool PC
This can be 3D Printed in SLS Polyamide and fits an inWin Chopin ITX case, no screws required. LEDs, Powerbutton and front panel clicks right in.
This is a reworked version of V1 that I printed where I strenghtend the clips - it should now hold on tighter to the Chopin's frame. But I have never printed this version.
Fair warning: My USB/Audio board was a bit bent out of shape and after some wiggeling I got it into position. In this V2 file I changed the positions of the USB holes to fit...
7,411
FYI, it's around US$39 to print in PLA with Shapeways after converting the file to .stl, or about US$70 in Shapeways strong/flexible
Reactions: BrotherStein
