Motherboard 4-Pin fan angle adapter?
gamecrusader
I have the ASROCK Z590M-ITX/ax and CHA_FAN2 (case fan header 2) is located under the M.2 heat sync. Do they make some sort of 4-pin angle adapter so I can plug a fan into that? I'm using a splitter off CHA_FAN1 for now, but I'd like to use that port if possible.
