Hi all,
Just to share a 3D printed mount for the EK D5 pump/res on the Ncase M1.
https://www.thingiverse.com/thing:2509505
It uses the internal front SSD mounting holes, so it's pretty easy to fit and remove.
I'm also thinking about making a bracket to fit to the top of the frame, for a slim 92mm fan. Suggestions on how best to do it would be very welcomed.
Thanks.
Thanks.
