3d Printable GPU AIO Mount
Cooling 3d Printable GPU AIO Mount 2017-10-21
Colinreay
198
490
Colinreay submitted a new resource:
3d Printable GPU AIO Mount - A bracket/backplate which allows you to mount your Asetek AIO pump to your AMD/Nvidia GPU.
This is a nice little bracket that will allow you to mount your Asetek style pump to a AMD or Nvidia GPU. The log can be found here for more information.
The bracket works by sandwiching the pump head of the AIO and the GPU die together via 4 screws and two brackets (one that holds the AIO down, with another on the backside of the GPU). It's a super simple yet effective design.
Hardware Needed:...
