I actually had a lot of fun making this debadged sleeper. I landed an Optiplex 9020 as a donation along with some other parts as giveaways. Practically all of the modding materials were very affordable through eBay. What started off as a home workstation, quickly evolved into a VR-ready SFF powerhouse all in the guise of an OptiPlex. On with the build...
Case: Dell OptiPlex 9020
Starting with the case, I debadged all Dell identifiers (optiplex print and dell grill badge) also replacing the i5 sticker with a nice matching black/gunmetal i7 sticker along with very nice metal Noctua badge. The side panel underwent a lot of flow testing and cutouts were made in a variety of shapes and patterns before finally resting at a polycarbonate window with holes drilled specifically to channel in at the graphics card. Custom LED lighting was achieved by simply tapping into the 12V line. The case also received an upgraded Noctua A8 PWM fan.
Power Supply: Dell OptiPlex XE2 PSU
While absolutely true, the power supply is proprietary, I found out that an OptiPlex XE2 had a nice 70W gain over the stock 255W PSU and had identical proprietary connectors. The 255W PSU was, without a doubt, sufficient to power everything but hey, 315w definitely makes you feel a bit more secure. I later upgraded the fan to a Noctua NF-A6, removed stickers and gave it a coat of matte black paint for better heat dissipation.
EDIT: I ended up going back to the stock fan. I can't fully recommend upgrading the PSU fan as the Noctua hasn't been totally compliant. I will report back with more developments after I get better test results.
CPU: i7-4790K with Noctua NH-L9i Cpu cooler
A nice hearty upgrade was made from the i5-4590 to the i7-4790K and while some tuning allowed the processor to be stable and consistent at 4.4GHz, this also had to be reflected on a proper cooling solution. More testing was done originally with Arctic 80mm fans using the OEM Dell heatsink and shroud, but ultimately with some minor case modifications, the Noctua NH-L9i was the best solution and fit absolutely perfectly, cooling very efficiently and silently.
Memory: 32Gb (4x 8Gb) Hynix DDR3 1600 PC3-12800
Nothing special here. Modules were later fitted with aluminum heatsinks.
Graphics: ZOTAC GeForce GTX 1050 Ti 4Gb (low profile)
During the time this build began a few months ago, probably the best option for a low profile PCI-powered graphics card and YES, Oculus ready/compatible A custom firmware was later uploaded allowing quieter idle RPMs and more efficient throttling on load. A note: the OptiPlex motherboard forced me to use the PCI x4 which I was a bit nervous with at first but honestly worked flawlessly with no loss as the 1050 Ti didn't require full lane saturation. x4 worked as good as x16.
Storage: Kingston HyperX Savage 480Gb SSD & Seagate Firecuda 2Tb SSHD
I actually found the HyperX in a discarded laptop - it was later fitted with a optical disk drive caddy, replacing the stock optical drive entirely. I later picked up a Firecuda for a bargain of $75.
Conclusion
As mentioned, I never intended for this but ended up being inspired to maximize this nice little SFF. I think the only costs I really spent was on the graphics card and Noctua fans (I later sold the i5-4590 and some other stuff to cover the cost of a 2nd hand unOC'd i7-4790K @ $190) but I have NO regrets going with the top of the line for fans - you really do get what you pay for. Figuring if I was to make this VR-ready, this is going to require serious upgrades and I couldn't skimp on cheap fans (sorry Arctic, but those fans were terribly loud, and the OEM fans screamed like jet turbines). Testing/tweaking the fans was quite the process though. I managed to achieve this using SpeedFan set with startup automation and was able to find the right PWM control headers. The CPU fan is triggered to CPU temp (the NH-L9i is a little beast and handles the i7-4790k very well on load by itself) while the case fan is triggered to GPU temp as the graphics card when under load will be first in the way of airflow and will reach higher temperatures. One inevitable and unavoidable annoyance is the fan alert on startup that can't be bypassed since using non-OEM fans: the motherboard is expecting certain RPMs at startup that simply aren't a match, but regardless the fans work 100%. Also to note that the fan headers had to be rewired to the Dell proprietary fan connectors (no surprise here). Again to mention the custom firmware upload to the graphics card made a world of difference reducing a very loud idle RPM. This (re)build was a total joy to make, and I really enjoyed the niche of taking something produced in mass, hulling it out and re-engineering it to something truly unique. I look forward to another project like this and always any requests, questions, suggestions or comments are welcome
Conclusion
