1080 vs 1080Ti VRM ?
tinyitx
2,273
2,334
Hongkong, CHINA
It is not compatible.
The Gelid kit fits 1080/1070 FE. So, when you compare their PCB layout with your Asus Strix 1080Ti, it is very different.
But your Asus Strix has its own plate already, which more or less acts as a heatsink. However, I do not know if you can keep that when you install the Accelero Etreme III.
Reactions: MultiDoc
MultiDoc
304
197
UK
Thanks tinyitx, I'll probably go ahead this afternoon and do the install of the Accelero. I don't know if the strix's plate can be retained yet but will try it and see. Otherwise I;ll install separate little heatsinks on each VRM and DRAM chip.
Cheers
