NCASE M1 SFX-L bracket
.SKP & .STEP NCASE M1 SFX-L bracket 1.1
A custom bracket I designed to mount a SFX-L power supply in the NCASE M1 in a similar position and orientation to how the stock ATX bracket. The idea is that with the SFX-L PSU mounted with the fan facing rearward the modular connectors would just clear the end of a 10.5" card like the reference GTX 980.
Here's the prototype installed
There wasn't enough interest to do a production run of these so here are the file for anyone interested in fabricating it themselves.
Note: the design is intended for the bracket to be made of sheet metal, 3D printing it as-is probably won't work very well.
Author
Downloads
67
Views
3,889
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from jeshikat
