Resource icon
Other Corsair short straight Terminal Block for XG7 Waterblock 2021-05-01
The Corsair terminal design I used to create a straight low profile G1/4 terminal for my watercooled S4M.
I submitted it to be laser cut in 3 layers and then used JBWeld 4 to adhere the layers together.
The layer with the G1/4 terminal holes must also be tapped using a G1/4 tap (I used this one).
The G1/4 terminal layer should be 5.6mm and the other two can be thinner at 3mm.
I recommend purchasing extra spares of the G1/4 terminal as you may screw up the tapping like me.
These DXF files can be opened in Fusion or sent directly to a laser cutting service like Ponoko.
Author
Vaderator
Downloads
Views
1,417
First release
Last update
Rating
0.00 star(s) 0 ratings
