Please read the README. By opening the SVG files, you are automatically consenting to uphold the standards outlined in the GNU GPL 3.0 Public License, but applied to a design (Not a program).
To install, I would screw the attachment onto the fan (with the 3mm part on the bottom of the stack). You can laser cut with any material you want, however, so your material thickness may be different.
Specifications will be listed within the README.
This design was made with Inkscape. Thanks to them for developing nice software.
