This can be 3D Printed in SLS Polyamide and fits an inWin Chopin ITX case, no screws required. LEDs, Powerbutton and front panel clicks right in.
This is a reworked version of V1 that I printed where I strenghtend the clips - it should now hold on tighter to the Chopin's frame. But I have never printed this version.
Fair warning: My USB/Audio board was a bit bent out of shape and after some wiggeling I got it into position. In this V2 file I changed the positions of the USB holes to fit better hopefully, but again, not tested. If you want to be sure, measure your Frontpanel and move around the holes in a CAD Software like Fusion.
