Other What's on Taobao
Bizanti
hey,
This case "XiKii FF01" looks cool I only found 2 videos
Reactions: NinoPecorino
Bizanti
hey,
and
Analogue Blacksheep
838
695
Rider R2 V4 is now on AliExpress and Taobao
So far I've only found one video on Bilibili.
7.9L, 68mm CPU cooler, Water cooler support, 200mm GPU, SFX-L support.
stefs12
Bhiner is cheaper, but i am afraid because i read some bad comments about them.
Is still expensive, but it cheaper, maybe i will find another agent with lower price, put ur advices.
Also, graphic cards cant be sent like common gods or can?
slb011
Hi,
Looking for a taobao clone (or close to as possible) case of a dan-c4?
Sunmilo M01 comes to mind but its slightly larger and I prefer the aesthetics of the dan-c4, and it also doesn't have the inverted layout which I would like as it helps a lot with gpu thermals, though I know the cases do offer some customisation so maybe it would be possible to have an inverted layout
ZZAW B6 also looks perfect for my needs except I hate the ventilation design of the side panel. I've messaged the seller on aliexpress to see if that is changeable
Streacom DA2 is also an option but it doesn't have clearance for a 3slot gpu and is larger than the others mentioned, I feel in the future if current trends are anything to go by, 3-slot gpu's will be the standard for xx80 and xx90 gpu's
I currently have a cube x1 and while I've had a positive experience with it, I'm looking to go back to air cooling with my next build. I have a custom loop in here and don't enjoy the maintenance involved. I also need to take it on a plane every now and then which requires me to bleed it out and refill etc, its all just a pain to deal with and I'd rather simplify my build.
TLDR; Looking for something close to a dan-c4 clone. ~<15L, no riser required, inverted layout possible (gpu on top)
ignsvn
By Toutatis!
1,712
1,651
Hi,
What about the Ncase M1 Evo? M1EVO - Angled Kit - Black Color – NCASE (ncased.com)
(Just my opinion, it's harder to match the aesthetics, easier to match the spec :) )
slb011
I have considered it but I'd rather take a sliger s620 in order to fit a top tier cpu cooler for not much increase in volume.
When considering >15L cases then the NR200 has to come under consideration aswell
Sliger s610 might be looking like the best option to me, fits almost any gpu, a thermalright pa120 mini and can be inverted at 13.3L.
I'm not too bothered about mATX compatibility or 4slot gpu's because for those beefy gpu's, deshrouding or a raijintek morpheus would likely be a better option for cooling while keeping a similar form factor.
Also had a look at an acat x2 but seems expensive compared to a sliger and is uninvertable, nice aesthetics though.
Reactions: Arboreal
chx
553
282
