ChinStrap
199
178
With no ETA on Velka 5 replacement, I went ahead and bought a Velka 7. The Velka 3 will get put in storage until a 3060ti replacement (that is worth it) comes out. Fitted with a Corsair SF600, 13600k, Gigabyte Z690I Ultra Lite DDR4, 2x16GB B-Die, 2TB 990Pro, and Dell OEM 6900XT. I’m happy with it.
Reactions: L91 and rfarmer
L91
62
68
www.youtube.com
Seems to have been put on back burner for foreseeable future. Is there any info for changes available anywhere
Reactions: Atlas
VELKASE Michael
VELKASE
743
914
Rev 3.0 launch will be this October 16th.
Velka 3 rev 3.0
  • $159.99 USD, including US shipping. +$19.99 for PCIe gen 3 cable / +$89.99 for PCIe gen 4 cable
  • 184 x 99 x 219 mm / 7.2 x 3.9 x 8.6 in
  • 3.99 L external / 3.81 L internal volume
  • 1.4 kg / 3.1 lb
  • 1.0-2.0 mm powdercoated galvanized steel construction
  • Textured powdercoat with improved scratch and fingerprint resistance
  • Better rubber foot adhesion
  • Full powdercoated galvanized steel construction
  • Symmetrical top vents when PSU is on the bottom
  • Motherboard compatibility fixes
  • Slightly fewer screws involved in assembly
  • Larger power button without LED
  • 5 mm optional side panel offset instead of 2/4 mm. Cleaner appearance when used
  • Motherboard: Mini-ITX
  • PSU: Flex ATX (150 mm length)
  • CPU cooler: 37 mm height
  • Graphics card (LxWxH): 175 x 43 x 148 mm (includes space for cables; 16 mm minimum required)
  • RAM: 42 mm height
  • Storage: 1x 2.5” drive
  • PCIe riser cable: required for graphics card installation. 108 mm hole pitch, 25-30 cm end-to-end.
  • Handles: 128 mm hole pitch, 4 mm screw diameter
Velka 5 rev 3.0
  • $179.99 USD, including US shipping. +$19.99 for PCIe gen 3 cable / +$89.99 for PCIe gen 4 cable
  • 178 x 102 x 283 mm / 7.0 x 4.0 x 11.1 in
  • 5.14 L external / 4.92 L internal volume without stand
  • 1.4 kg / 3.1 lb
  • With included optional stand: +44 mm height, + 0.8 L volume, + 0.2 kg / 0.5 lb
  • Direct GPU IO connection with included stand. Compatible with straight and angled external cables protruding <60 mm from graphics card IO. Internal display extensions no longer required.
  • Horizontal and vertical GPU shift: extra clearance and compatibility for internal display extensions, improved “pass-through” cooling for certain graphics cards
  • 2x 40 mm fan mounts
  • Graphics card (LxWxH): 270 x 43 x 143 mm or 261 x 43 x 148 (includes space for cables; 16 mm minimum required)
  • RAM: 42 mm height
  • Storage: 1x 2.5” drive. 3x extra 2.5” drives with 200 mm and shorter graphics cards
  • PCIe riser cable: required for graphics card installation. 108 mm hole pitch, 29-35 cm end-to-end.
  • Case fans: 2x 40 mm
  • Internal display extensions: 27 mm hole pitch, 4 mm screw diameter maximum. 35 mm for female end (+10 mm with card shift and equal card height reduction). 11 mm for male end (+11-25 mm with card shift and equal card length reduction).
Velka 7 rev 3.0
  • $199.99 USD, including US shipping. +$19.99 for PCIe gen 3 cable / +$89.99 for PCIe gen 4 cable
  • 178 x 115 x 304 mm / 7.0 x 4.5 x 12.0 in
  • 1.4 kg / 3.1 lb
  • With included optional stand: +44 mm height, + 0.9 L volume, + 0.3 kg / 0.6 lb
  • Official SFX-L PSU support when dedicated 2.5” drive mount is not used
  • PSU: SFX, SFX-L
  • CPU cooler: 48 mm height
  • Graphics card (LxWxH): 290 x 43 x 143 mm or 281 x 43 x 148 (includes space for cables; 16 mm minimum required)
  • RAM: 53 mm height
  • Storage: 1x 2.5” drive (with SFX PSU only). 3x extra 2.5” drives with 220 mm and shorter graphics cards
L91
62
68
www.youtube.com
The stand makes the case look off/odd with the power button at top. I'm happy internal display extension cables are still possible. Pass through GPUs, specially ones that blow towards PSU are terrible for Velka 5. They causes Flex-ATX PSUs to sound like a jet engine due to GPU heat exchange.
GucksTV
242
495
www.youtube.com
So I've got the new Revision 3.0 and compared it to my Velka 7 rev 2.1 which was equipped with a Nvidia RTX 4070 Founders Edition, ASUS ROG Strix B650E-I, RYZEN 7600 (right now I use a delidded 7800X3D), SilverStone EX850R with 12VHPWR, TeamGroup VULCANα DDR5, Alpenföhn Black Ridge (yes...I've got a pre-production Mounting-Kit for AM5 *spoiler*) and yes it does fit both the rev 2.1 and 3.0 with that specific board. Check it out:
Thank you @VELKASE Michael for the opportunity to test your beautiful new case! <3
By the way, I will make a live stream in two days at Friday 4pm (German time) where I will be putting everything together and show off the internal GPU-offset with the RTX 4070 for better passthrough airflow & temperatures.
L91
62
68
www.youtube.com
By the way, I will make a live stream in two days at Thrursday (5pm german time) where I will be putting everything together and show off the internal GPU-offset with the RTX 4070 for better passthrough airflow & temperatures.
BR AM5 kit, very nice 😁 I'll have a video out in few weeks for Velkase revisions. Sadly, an unforseen issue occurred with original footage and caused lower quality or bitrate recording, resulting in noisy image. Can't say I'm not little sad, but I'd rather redo the video, than push out something less than what it can be. Sorry guys
Feel free to check out Velkacase content on IG in meantime
Reactions: MatiMike and HWI
k0n
219
285
Swapped premium feel for robustness
I don't get it... always thought the slapped on aluminum was weird.
steel case + 5mm aluminum plate = premium XD
I liked the original Velka 5... uncompromising(*) and small footprint.
*I'm sure not everyone liked the I/O on top or the SFX-PSU mounted directly onto the outer shell, but... it was the way to go!
neiru37
24
Really curious how the GPU shift works and how that improves temps for pass through GPU's. Can you share a bit more detail on how this is achieved?
Reactions: GucksTV
L91
62
68
www.youtube.com
v2 cases arguably more aesthetically pleasing with smooth surface finish and nice front panel. Of course aesthetics are subjective, so not to mince words. Each to their own. I'm aware of the practical benefits of the v3 changes and case is functionally much improved, but I like aesthetically pleasing cases, what can I say 😉 in any case, you do get used to it so not big deal
HWI
59
42
I like the look of v2 better as well. That being said, if I didn't already own a v2 I would not hesitate at all to buy a v3.
Reactions: L91
Snerual
174
204
Great video. The case looks very robust. It's a shame the Gigabyte and MSI 4070Ti's are juuuuuust a bit too thick to fit (at 50mm)
Reactions: L91
