Concept Two Portable SFF Gaming Cases - under 7L and under 5L (w/ 500W PSU)
firewolfy
424
836
KSliger,
You mentioned broadening your versions to cover SFX and such. I have been working on a small ITX with SFX too. I have a designer friend modeling it for me (since I stink at 3D). I'd love to compare notes and such. I'll let you know when I get a model back in the next couple of days.
firewolfy
424
836
I have found enough material to model you one on Sketchup. I'll let you try a converter then :D
I just DL'd your nano model off grabcad last week. Great work. It took a while to get it converted from SU to the IGS I needed but it looks like it worked great. For anyone who needs to convert I used viacad trial version and had to go SU to STP to IGS. Thanks man.
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
2,975
4,402
guilleacoustic.wordpress.com
You're very welcomed. I moved to Archlinux, so no more SU for me. I have to learn freeCad now :D
KSliger
Sliger Designs
May 8, 2015
855
3,186
KSliger,
Absolutely if you need anything - make a thread here!
I'm having issues getting the 500W FlexATX into a project at a stable volume.
I was able to get 1 piece sample and can get a one time 25 piece preproduction, and 100 piece MOQ one time - then after that I have to hit 300 MOQ. I'll keep this thread updated if I manage to pull anything off.
jmsantos1983
107
23
So, regarding the case that looks like the DAN case, any progress? Any plans on the implementation of the g-unit psu?
Slim disc drive option?
Water cooling addon?
