firewolfy
424
836
Here are some more ideas I have been chewing on. Let me know if you see anything beautiful, thx!
Boil
1,253
1,094
Can we see front left-aligned I/O with a Hutzy XS-esque vent pattern, but with your current LARGE cutouts & honeycomb mesh backing…?
firewolfy
424
836
With swappable/customizable front panels, can't people just get a front panel without IO? I thought that was one of the major selling points of this case.
Good point, thx for that. Have to think about how to put that power button back on the back of the case, for those who wouldn't want anything on the front.
Reactions: 3lfk1ng and cmyk78
KMPKT
3,382
5,936
Don't you already have a cut out for it on the back? If you don't, you could just have it standard on the back and optional on the front. If people are really worried about having an unfilled bulgin hole on the back of the case, I'm sure a simple black rubber plug could be sourced to ship with the case for next to nothing.
NRG
289
359
No preference on the I/O side, So long as it's not in the middle! And those vents look a lot better :)
Boil
1,253
1,094
Left-aligned (I am assuming) is because that is the side with the GPU; so, the clearance is there…
firewolfy
424
836
Yes, putting it over on the gpu side means the cpu side is clear for easy cabling and psu connections.
exodus
I still vote for no front plugs. But this new design look good as well. But i think if the USB port could be placed for i e. on the left side of the case, it would look a a lot better with just power and audio plugs in the front.If those have to be in the front. Those would also match nicely with the front screws. it's the USB ports that looks ugly as hell. USB ports could be put on the top front also.
firewolfy
424
836
I am receiving a sheet of the hex perf within the next few days. I'll check it out and post updates.
Reactions: cmyk78
