Show your new toys Topic
Solo
863
1,438
I, like @GuilleAcoustic, got some headphones as a birthday gift.
ignsvn
By Toutatis!
1,711
1,650
So, I'm slowly accumulating components for my 2nd rig.
Historically, CPUs in the Athlon category are power hungry. The current iteration - Athlon 3000G - is not an exception. It has 2 cores & 4 threads, running at 3.5 Ghz base clock. Not to mention the integrated Radeon Vega 3, with 3 Radeon graphic cores running at 1100 Mhz. At total combined TDP of 35 watt, the Athlon poses a serious challenge to any PSU. It will be interesting to see how the V750 will fare.
Arboreal
810
810
You guys have now got me worried about the 120W brick on my Deskmini...
It seems to be coping with my overpowered Athlon 200GE, but I may regret that 3400G I've bought without getting a bigger power supply 🤔 🤣
m-i-c-k-e-y
65
65
An update at this post. Had an early treat for myself this Christmas.
Updated: My Shuttle DH370 i9-9900 32Gb to a Lenovo P360 Ultra i7-12700 RTXA2000 128Gb.
Added: Audiobyte Hydra.Hub Streamer/Converter, Puritan PSM156, Fiber Media Converters + LPS
Lenovo P360 Ultra specs:
ignsvn
By Toutatis!
1,711
1,650
Not as extravagant as the post above me, but yesterday I purchased polishing bit for my Proxxon rotary tool. Also, my short generic wifi antennas have arrived.
Spoiler: the short antennas perform admirably for its size, but unfortunately there's a wall between my PC & my router, so the signal strength got affected pretty badly. For context, on 5Ghz band my default Gigabyte Aorus antenna got 78% signal strength while the short antennas got 48% signal strength. I still managed to load Youtube 1080p videos without waiting/buffering, but the margin is a bit tight for my taste. Also, for context, my router is rather old TP-Link Archer C7 (or C1200, can't remember).
I will still keep them though, as I believe the signal quality will improve in a more open area/room & it's really useful in tight spaces.
Edit: how I checked wifi strength on Windows 11: open command prompt, type & run "netsh wlan show interfaces"
Edit 2: it seems that on 2.4 Ghz band the short antennas fare much better. The Gigabyte antenna is already inside the box, so I compared with the MSI antennas that come with the B450i Gaming Max AC. They both get at around 82% signal strength. So yeah I guess it's true that 5Ghz band is faster but more susceptible to interference, while the 2.4 Ghz is slower but more.. robust.
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
2,975
4,402
guilleacoustic.wordpress.com
Above is a Reviung34 (non-split) keyboard kit (gtips/reviung GitHub) :
  • Black PCB with black FR4 switch plate
  • Laser-cut 3mm EVA foam plate (goes between the PCB and the switch plate)
  • Clear acrylic bottom plate + clear acrylic diffuser
  • PRO Micro USB-C (black)
  • Gateron PRO Yellow Milky switches
Note: I've ordered the kit from 42. Keebs and I highly recommend them. Petr is a lovely guy, everything was well packed in a cut to size shipping box
Above are the keycaps I'll go with. They are from the Little Pilot keycaps set (KAM profile). I have both the Alphas and the Ergo subsets. They are thick dye sublimated PBT with a glossy finish.
I'm planning to use the Seniply layout (based on a modified Colemak-DH). KAM profile being uniform means that it is easier to swap keycaps to try exotic layouts.
Next step: Smol SMD diodes and LEDs soldering 😭 .... I'm not looking forward to it 🤣
Dawelio
Awesomeness
524
439
As an huge Transformers and specificially Optimus Prime fan, I ain't gonna lie, that is cool! :)
steelfractal
Aug 15, 2019
377
465
so things happened money was spent things were bought and it didn't even take a month from start to finish( ha you thought so no this is an endless pit of doom and despair) after talking with @TutorialIsland @GuilleAcoustic and @Kaji and huge thanks to all of them guiding me through the obstacle course of a rabbit hole that is HiFi speakers amps and headphones in the sff discord they won me over so now I am the proud owner of a pair of HIFIMAN Sundara's and a
Motu m2 audio interface and I am not done yet with some more cool audio gear getting bought when I get paid again💸💸💸😭 counting on you guys to help with getting the good stuff again
GuilleAcoustic
LOSIAS
Jun 29, 2015
2,975
4,402
so things happened money was spent things were bought and it didn't even take a month from start to finish( ha you thought so no this is an endless pit of doom and despair) after talking with @TutorialIsland @GuilleAcoustic and @Kaji and huge thanks to all of them guiding me through the obstacle course of a rabbit hole that is HiFi speakers amps and headphones in the sff discord they won my over so now I am now the proud owner of a pair of HIFIMAN Sundara's and a
You're welcome. Hope you like your new gears.
I'll repeat myself, but I can't help but call those the Hifiman Tsundere 😂.
Nice setup by the way, very clean.
