RTX A2000 "KalmX Edition" - probably the fastest SFF friendly passive cooled GPU to date
REVOCCASES
REVOCCASES
Apr 2, 2020
2,068
3,348
www.revoccases.com
It's been a while since PALIT released their passive cooled GTX 1650 KalmX and I haven't seen anything comparable with "next gen" performance. Of course you could put an RTX 3080 in a MONSTERLABO, HDPLEX or TUREMETAL case but if you prefer to have a standalone, passive cooled GPU for your custom build there aren't many options...
long story short, here is my DIY solution to turn the RTX A2000 into a passive cooled "KalmX Edition"
Specs:
  • GPU: RTX A2000 6GB
  • Cooler: ACCELERO S1 R2 & CNC machined copper plate
  • Dimensions: ca. 2 Slots, 135mm height, 220mm long
performing the mod:
besides the A2K and the ACCELERO S1 cooler, we need a 3mm copper plate for mounting and covering the VRAM...
the copper plate will be soldered with 138C solder paste to the heat sink...
I am using a small, cheap "Pizza Oven" for this job and controlling the temperature via a temp probe... the process is a little bit tricky because if you heat it up too much, the heatpipes will come loose from the cooler itself...
as soon as the solder paste melts you're good and can stop the oven...
last but not least I painted the modded heatsink with some temperature resistant spray paint...
mounted to the A2K with two M2.5x8mm screws and done...
next up, some benchmarks...
REVOCCASES
REVOCCASES
Apr 2, 2020
2,068
3,348
www.revoccases.com
now let's see how it performs...
stock settings, horizontal fin orientation:
stock settings, vertical fin orientation:
custom V/C curve, horizontal fin orientation:
custom V/C curve, vertical fin orientation:
Benchmark results, custom V/C curve, vertical fin orientation:
summarizing: it works great! even at stock settings it does not throttle and performs just as good as with the noisy stock cooler. For best (passive-) cooling and performance however, it would be ideal to place the GPU in a traditional layout case to support natural airflow trough the fins and adjust the V/C curve in afterburner to something like 1500 Mhz @ 750mV
msystems
792
1,389
Amazing work fabricating your own base plate and figuring how to solder it! Looks very clean and no harm to the original heatpipes.
Reactions: REVOCCASES
REVOCCASES
REVOCCASES
Apr 2, 2020
2,068
3,348
www.revoccases.com
r_san
What a great idea, I just bought a accelero S2 to glue on my quadro p620, hopefully it will be easy to adapt
r_san
BikingViking11
93
167
My streaming PC is entirely fanless...minus the GPU. I'm currently using a GTX 1650 with plans to add a passive cooler to it. Well, that was until I became aware of the A2000. 20W less TDP and reportedly up to 80% more muscle...thanks for this thread.
Kroel
This is what i want!
Already found an Accelero S1 and looking to have a copper plate machined for me.
I was just thinking. Why not drill a few extra holes in de copper plate and attach the Accelero using screws and some regular thermal paste?
REVOCCASES
REVOCCASES
Apr 2, 2020
2,068
3,348
www.revoccases.com
You can try if you don't like to use solder paste, but cooling performance will be worse because solder has way better thermal conductivity...
P.P.A
Thank you @REVOCCASES for creating this mod & releasing the DXF file for it. I'm looking to replicate it with an Accelero S2 (although, comparing it to the S1 in the photo, now I'm not sure that the two less heatpipes are going to cut it). Since SendCutSend don't appear to ship to Germany, can you recommend similar services that do?
(Alternatively, if you're willing to sell this prototype, I'd be very much interested.)
