rgb ram modules for nfc s4 mini
Elerek
228
165
Currently newegg has all corsair memory on sale for 15% off with a coupon code, which puts their rgb ram in line with the t-force nighthawk rgb ram for price.
Will either of these kits fit in the s4 mini? I found one source saying the corsair ram is 49mm, but can't find a measurement on the nighthawk kit.
RenG
139
69
According to tweaktown, they are 53mm in height. S4M officially supports 40mm of RAM height only. There is a small wiggle room but it won't be enough for these kits (49 or 53 mm).
Elerek
228
165
I actually did buy the corsair ram after finding a guy in Guy's discord who used them no problem in an s4m-c.
Apparently either there are some manufacturing tolerance differences, because I'm pretty sure clearance didn't change between s4m-c and s4m, but he had a mm to spare and I had to take the reversible grills off the ram to get it to fit and it still just touches the side panel.
I'll try to post some pics tonight.
