Completed REVOCCASES MIT-EVO | Compact Steel & Wood ITX Tower
REVOCCASES
REVOCCASES
Apr 2, 2020
2,065
3,341
www.revoccases.com
The MIT-EVO is based on the N0RDR1 design and features the classic layout of my MIT1 ITX Tower...
  • Case Volume: ca. 9L
  • Material: Steel & real wood
  • Cooler: Thermalright SS135
  • PSU: SFX / SFX-L
  • GPU: ITX size
  • Front Fans: 2x 120mm, max. 25mm (Arctic Slim recommended, for easier cable management)
  • Rear Fans: 2x 80mm or 1x 92mm
  • Bottom Fan: 1x 120mm slim with 1-slot GPU / de-shroud
The design is open source / free-to-use for personal projects and the drawings are attached here to this post... enjoy!
  • MIT-EVO.zip
tinyitx
2,279
2,338
Just curious. EVO probably refers to 'evolution'. So, is there a meaning behind the name MIT (or MIT1)?
BTW, are you back to Germany, HK or still in Guangdong?
Reactions: Arboreal
Neathdrawls
260
480
Thanks for the wonderful case!
Easy to build in and quality is top notch as usual!
