Limited quantity available now: REVOCCASES.COM
RCC-SMALL1 provides a 4L package if you are looking for:
Features:
Example configuration:
Custom made panel designs: starting from EUR 15,-
Build instructions:
1) assemble your SSD(s) to the bottom of the case and route the cables
2) install your motherboard and plug in all cables
3) install your graphics card
4) install the power button and the case fans on the faceplate. I recommend making the fan on the GPU side intake and on the CPU side exhaust.
5) install the faceplate and check if everything is hooked up
6) if you like you can stick some dust filter mesh to the top cover.
7) install the case feet (gold is optional, standard is black)
8) ready to rock
- a rock solid compact case
- decent CPU and GPU performance with internal power supply (brickless without compromise)
- lots of internal storage for Games, Movies, Work, etc...
Features:
- Solid aluminum extrusion chassis, anodized
- 4L volume (225x254x70mm)
- low profile dual slot GPU support, riser included
- up to three 2.5" SSDs plus M.2 on your motherboard
- support for two 60x25mm case fans
- 41mm CPU cooler clearance
- support for internal MEANWELL RPS200 plus ATX DC PLUGIN
- (optional custom made top covers upon request)
- (optional dust filter mesh)
- (optional gold plated screws and feet)
- (optional internal 200W power solution by G-UNIQUE & REVOCCASES)
- 65W CPU (Intel or AMD)
- GTX1650 LP dual slot GPU
- ID-COOLING IS-30 with NF-A9x14 HS-PWM fan /or/ NOCTU NH-L9
- two NF-A6x25 PWM case fans
- MEANWELL RPS200-12-C and G-Unique Archdaemon PLUGIN
Build instructions:
8) ready to rock
