Question: What is the differences between Geeeks A30 and A40 and some more questions about them
Jeeves
Hi all,
The main difference between the the Geeeks A30 and A40 is that A40 is wider and allows SFX power supply. I want to know if that is the only difference.
Can the A40 fit cards that the A30 cannot? And what cards can the A30 fit? (like can a mini version of a gtx 1070 like this one).
Thanks in advance and sorry if the formatting is bad.
7,206
According to the specs, the A40 is also slightly longer at 230mm instead of 211mm. The A40 is bigger all around, at 10.7L versus the A30's 8.3L.
That 1070 will fit both I'd say.
Reactions: Jeeves
