Discussion Performance per litre - Round 4
morj
352
685
Did you have to get rid of something for that?
Yeah, they got rid of the active SSD heatsink, so no big deal. SSD performance is not measured by PPL.
Also mad props to minisforum, they released basically an off-the-shelf solution with crazy high PPL. With such products available there's a really slim chance a build with top of the line GPU (say RTX 4090) can hit it.
Consider this: to get 2M PPL (assuming same CPU score of 12775) a build with a 4090 (which has around 33500 GPU score) must have a volume of approximately 1.6L:
log_1.5 ((12775 * 33500) / (100 * 2000000)) ~= 1.66
(12775 * 33500) / (1.66 ^ 1.5) / 100 ~= 2000984
For reference, Dell OEM 4070 GPU (smallest 4070) is around 1L in volume (with PCI slot excluded).
chinevo
SFF Recordsman
May 11, 2017
151
262
Congrats, impressive scoring!
How quiet is this tiny thing?
Surprisingly very quiet and completely silent when idle. I think it's due to liquid metal.
Watch this and this videos for more info about noise.
What you did is keeping the inner stock casing and replacing the top and bottom panels with thinner ones, right?
Only replaced the top and bottom panels
Stock vs Custom:
Yes, I got rid of the active SSD heatsink
source: https://www.techradar.com/pro/minisforum-mercury-em780-review
No DC barrel here, GaN USB-C charger fully compatible with this board.
USB-C 5A limit is respected with this low power 65W, but what about the problem with the USB Power Delivery reported earlier with such Gan chargers?
Does the board have an integrated 'USB-PD dummy trigger PCB'?
What do you guys think, @msystems, @SFFMunkee ?
Any usb-c chargers, that I tried, works well - apple, xiaomi, stock, rozetka.
But usb-c port on the front don't charge my wireless mouse or keyboard.
Please show us a picture of it next to a soda can 😄
Yes, sure ;)
morj
352
685
By the way, this whole thing got me thinking about the PPL formula. Why are we measuring performance per cm^4.5?
Explanation: 1 liter is 1000 cm^3 (cubic centimeter). So the formula has Build Volume^1.5, which makes it (cm^3)^1.5 which is (cm^4.5). Performance per something that is over 4 dimensions 😱
Moreover, for builds of, say 4L in volume we have 4^1.5 = 8, so actually 2 times the volume (of penalty) due to this exponent.
On the other hand for a build of 0.25L volume we have 0.25 ^ 1.5 = 0.125, so actually 2 times LESS the volume due to this exponent.
So basically the exponent in the formula IMMENSELY favors the < 1L builds due to the way exponents work. We are looking at like 4x advantage over a "normal" build.
EXAMPLES:
@petricor's build without the exponent: (34,565*33,304)/(5)/100 = 2302305.52
@chinevo's build without the exponent: (12775 * 2688) / ((0.198 + 0.053)) / 100 = 1368095.61753
Is this feature of the PPL formula intentional?
chinevo
SFF Recordsman
May 11, 2017
151
262
EXAMPLES:
Oh yes, the rating is unfair because @petricor is not in the first place 😀
It's a joke. To put it seriously, the rating is really unfair cause we have performance ^ 2 (performance*performance) in the numerator and volume ^ 1.5 in the denominator. So, performance has more weight than volume. The fair formula, in my opinion, should look like <performance>^1/<volume>^1 (performance per liter). For example: (Multipier1*<GPU score> + Multipier2*<CPU score>) /<Volume>. Or separate ratings for GPU and CPU: <CPU score>/<Volume> and <GPU score>/<Volume>
For example, gamers have simple formulas
<Average FPS> / <Price> or <Performance> / <Watt>
rather than something like this:
<FPS in game1>*<FPS in game 2>/ Dollar ^ 1.5
or
<Performance1>*<Performance2>*<Performance3>/ Watt ^ 2
Good point, seems nobody expected sub 1L builds 🤔
Maybe it's time for a new round with update calculation?
"Competition ends at 25 entries (new round with new benches starts after)"
So, we need 6 more entries and go for round 5
morj
352
685
I'm not saying the rating is unfair, I was just trying to understand how the minisforum PC beat is so easily. Based on the raw numbers, the performance is not proportional to the volume, but the rating is off the scale.
I mean, it's not fun when something you can just go and buy for 600 EUR blows everything custom (like @petricor or @guryhwa builds) out of the water. 😉
msystems
792
1,390
I would assume the purpose of the exponent is to reward going smaller in general. If there are two builds which have proportionally the same performance, the exponent function causes the smaller one to receive a bonus. I find this is somewhat logical for ITX desktops because the smaller you go, the more inefficient your build is, because you have things which are standardized/ fixed in volume, requiring more extreme customization the smaller you go.
But indeed, when the total volume is less than 1, it causes a bit crazy results. It needs a clamp on the lower bound of the volume.
I'm not sure what the best mathematical approach is, but i propose that builds with a total volume under 1L should omit the exponent from their ppl calculation.
That would still give the build above a colossal 1.3M score, but not a broken one.
Reactions: SFFMunkee
r0ger
Hi,
For small machines where the cooling system is shared by the CPU and the GPU, it is important to do the CPU and GPU benchmarks at the same time
In my nuc with passmark benchmark (setting duration very long), the cpu benchmark is 22,500pts, the igpu benchmark is 3,000pts, if I launch at the same time it drops to around 60%
Reactions: riba2233 and morj
chinevo
SFF Recordsman
May 11, 2017
151
262
Hi,
Important for what? To get a worse results? I prefer better 😀
PS: maybe it can be helpful for somebody. Here you can download 3D model files of my custom EM780 panels
r0ger
it's sure, it suits you 😀
but it's always interesting to know the results of the mini pc when using cpu+gpu in the same time
7,210
ASRock DeskMini X600
Ryzen 5 8600G
2x 16GB Teamgroup Elite DDR5-5600
DeskMini X600 Dimensions - 155 x 155 x 80 mm (1.92L)
Power Brick: 120w GAN supplied with DeskMini: 65 x 98 x 23mm (0.14L)
Total volume: 2.06L
Score: ((12870 x 2372)/ (2.06 x 1.5)) /100
(30527640/ 3.09) /100
98,794.95
System pics will be in the upcoming review article :p
Forgot the GPU-Z instance but I'm sure this'll do.
785
Ryzen 5 8600G
Total volume: 2.06L
98,794.95
CPU and GPU scores both seem low?
What's the RAM running at?
::EDIT:: Just tested my 5600G on my boring daily / stable settings - except I had to go back to BIOS and enable the iGPU and force it to be primary output.
Weirdly my CPU score is dreadful - maybe I should've waited a bit after restarting lolll
Second run the CPU performance is still way lower than I'd expect (in my PPL test I got 8840 CPU points..?) but whatever - I'd have expected the 8600G to smash the 5600G.
Ah well - we'll see what it can do when I get tinkering ;)
Reactions: riba2233
7,210
5600, stock settings on this one.
