CPU Low depth power button/switch?
smitty2k1
968
493
Does anyone have a readily available (in the US) low depth 16mm power button they would recommend?
I see a ton on AliExpress but looking for something sooner.
Ideally it would be black with white LED but I'm not too picky.
Gingerbeer
104
92
My son is home from uni this weekend and will have his S4 mini PC in his bag, so I can check the depth of the switch for you.
kelly_sparrow
how about this
robbee
n3rdware
864
1,359
I can see many when I search 'momentary 16mm vandal' on amazon. Some examples:
smitty2k1
968
493
I don't see your links but I was having trouble specifically finding low depth/shallow ones. I ended up getting this one, LED works fine even though it's a 12-24v rating:
