Enclosure Jonsbo C6 ITX Motherboard Fitment Problems
Mark13
176
222
Wanted to do an ITX motherboard & SFX power supply build in this inexpensive case. Unfortunately I could not install my Gigabyte Aorus B550 motherboard with its fixed rear IO panel in either of the two cases I tried:
A black one from Amazon & a white one from NewEgg. Both cases have the motherboard at least 1 to 1.5 mm too close to the rear panel. You must push the motherboard with enough pressure to bend the rear case panel outwards to try to install the board. In addition, on the black unit only 3 standoffs would properly align with the 4 motherboard mounting points. Case might work with a motherboard with a separate rear IO shield.
