Join the Smallformfactor.net HWbot Team.
It's time for a little friendly competition!
HWBOT is a 100% FREE to use online benchmarking repository.
The rules are simple:
1. Create an account.
2. Join the team.
3. Run benchmarks.
4. Submit your results.
Link to the team: http://hwbot.org/team/smallformfactor.net/#Members
Why should I run benchmarks?
- Your contribution(s) earn points for the smallformfactor.net team.
- It starts some friendly competition with other members of the Small Form Factor community.
- Competition helps to optimize builds and eek out performance that would otherwise go unnoticed.
- Teammates help each other by finding ways to improve their scores.
- The more points our team earns, the higher we rank among other teams worldwide.
As a lot of our builds share similar hardware inside various SFF chassis, this helps to ensure that our hardware is running at its best.
What is HWBot?
It's a website were you can browse processor and videocard specifications, and compare your performance based on thousands of submitted results. It's also an overclocking competition site. If you like tweaking your computer, you can send in your results and be handed out awards for best performing videocard / processor, etc.
- HWBOT is the official website for benchmarking/ overclocking enthusiasts.
- It's been around since 2006 as the gold standard in benchmark result submissions.
- Every record that has even been, was submitted to HWBOT for accuracy and validation.
How do I join the Smallformfactor.net team?
Step 1. Visit the website hwbot.org/
Step 2. Select the option to register
Step 3. Enter your username at it appears on the Small Form Factor Forums.
Step 4. Select the team.
Step 5. Complete your registration
Now what?
Run benchmarks and submit your scores to help the team.
You can benchmark your CPU, GPU, RAM, and HDD.
3DMark submissions will require a 3DMark account, you can make one here: http://www.3dmark.com/login
Is there an FAQ where I can learn more?
Absolutely!
https://hwbot.org/article/faq
If you have any additional questions, please ask them below and I will do my best to answer them.
Let the games begin!
Quick Links:
Download Benchmarks: http://hwbot.org/benchmarks
Submit Results: http://hwbot.org/submit
Browse CPU results: http://hwbot.org/hardware/processors
Browse GPU results: http://hwbot.org/hardware/videocards
To submit scores, you will need to have CPU-Z and GPU-Z installed.
The programs need to be opened and included in the screenshots that are submitted to HWBOT.
CPU-Z
GPU-Z
3DMark can be purchased on Steam here.
Step 1. Configure your forum signature on HWBOT's page and remember the 2 underlined sections.
http://hwbot.org/profile/
Step 2. Visit the URL to changes your signature on Smallformfactor.net
https://smallformfactor.net/forum/account/signature
Step 3. Select the option to input BBCode
Step 4. Alter the BBCode provided by HWBOT to match your:
A. Username
It needs to match the following example to function on this site.
Step 5. Click on Preview to view the changes, if you're happy, click on save.
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
I just looked at your scores - don't you dare push me down in the lists. :-P
I don't think you need to be concerned too much, I'd probably only threaten you if I somehow got my CPU to 5ghz+ territory since it looks like the scores are based on per core performance. Therefore I'm way behind at 22nd place. :)
Reactions: Kwirek
Kwirek
186
198
Ah that is correct, sorry to hear that.
Personally I'm slightly miffed about myself. If I had done my tests for the competitions one day earlier I'd been number one in the Rookie-league for the day. Totally unearned, but still. :cool:
Reactions: royalba94
msystems
790
1,387
Anyone else notice how tricky to keep a Nvidia GPU frequency perfectly stable on Boost 3.0 because of the automatic down-clocking from temperature. I try to keep temps within a small range, but then I still have to "pre-heat" the card up before setting the OC. Otherwise, it tries to boost too high when it cools down to 30C.
MarcParis
Apr 1, 2016
3,629
2,722
Well it's turbo boost 3.0...as long as you are under max temperature, it's similar across all cards with same gpu...meaning watercooling pascal board is pretty meaningless versus a good aircooling model..:)
Reactions: msystems
msystems
790
1,387
jØrd
S̳C̳S̳I̳ ̳f̳o̳r̳ ̳l̳i̳f̳e̳
sudocide.dev
LOSIAS
Jul 19, 2015
818
1,359
Good thing I tried this on a free tier first. So much for smashing out a 64 core run on an EC2 instance, Intel XTU wouldnt install :(
Click for big
EDIT: Thwarted by HWbot again :\
