News Gigabyte/ASUS/GALAX RTX 4060 Low Profile
Gigabyte is creating an RTX 4060 low-profile card: https://www.tomshardware.com/news/g...-be-the-first-low-profile-ada-lovelace-design
3 fans, single 8-pin, 2 slots.
Pie in the sky, but would love to see an RTX 4060ti (or more crazy RTX 4070) model at some point.
___
16/01/2023 Addendum
ASUS now has a 4060 Low Profile card.
188mm, triple fan.
___
19/04/2024 Addendum
Galax has a card
182mm, triple fan, but the PCIE cable is at the front which will affect clearance without a custom solution.
Will advise to look for something slightly bigger
Cases these will fit into (double check before you buy, not everything is available):
Lenovo P3/P360 ULTRA - 182mm* - Gigabyte (May require modding)/Adapter Needed
ZS A4DC V3 - 182mm* - Gigabyte (May require modding)
ZS D2 (D Config) - 182mm - Gigabyte/GALAX (Possible PCIE cable issue)
Gemcase C9 - 182mm - Gigabyte/GALAX (Possible PCIE cable issue)
Lone Industries L5 - 185mm - Gigabyte/GALAX (Consider PCIE adapter)
Custom_Mod SL3 STL 4.8L Rev.1 - 185mm - Gigabyte/GALAX (Consider PCIE adapter)
n3rdware Yocto - 185mm** (Guidance rather than a limit) - Gigabyte/GALAX (Consider PCIE adapter)
n3rdware Yocto+ - 185mm** Guidance rather than a limit) - Gigabyte/GALAX (Consider PCIE adapter)
ZS D2 V2 - 186mm - Gigabyte/GALAX (Consider PCIE adapter)
Custom_Mod Case MINI LP edit. - 190mm - Gigabyte/ASUS/GALAX (Consider PCIE adapter)
J-Hack Pure MK2 - 190mm - Gigabyte/ASUS/GALAX (Consider PCIE adapter)
Lazer3D HT5 - 194mm - Gigabyte/ASUS/GALAX
Lazer3D Cravo - 195mm - Gigabyte/ASUS/GALAX
CAPTAIN CASE V9 - 208mm - Gigabyte/ASUS/GALAX
REVOCCASES N0RDR1 Nano EVO - 210mm - Gigabyte/ASUS/GALAX
Metalfish 2 Plus - 210mm - Gigabyte/ASUS/GALAX
LZmod A24-V5 V2.0 - 220mm- Gigabyte/ASUS/GALAX
Silverstone Milo ML03 - 223mm - Gigabyte/ASUS/GALAX
Silverstone Milo ML04 - 223mm - Gigabyte/ASUS/GALAX
Metalfish G5 - 245mm*** - Gigabyte/ASUS/GALAX (MATX Board width)
Bug C1 - 245mm*** - Gigabyte/ASUS/GALAX (MATX Board width)
SKTC A10 - 245mm*** - Gigabyte/ASUS/GALAX (MATX Board width)
Silverstone Milo ML11 - 272mm - Gigabyte/ASUS/GALAX
Stifle
47
77
I picked up an LLW workshop V36pro case through superbuy a few months back (as well as a V21/V26) and I think this might just fit, I measure 182mm of clearance and I have 180degree 8-pin adapters but the shroud beyond the last fan could be trimmed a bit and still have plenty of room even without 8pin adapters.
robbee
n3rdware
864
1,359
There's a heatpipe under the shroud, I think you can shave off about 4mm max.
Reactions: Stifle
Stifle
47
77
Thanks for pointing that out. Ill be picking one up to attempt a build with everything I have in my work PC only replace PSU with HDplex GaN, 3060ti FE with this 4060 and Loque ghost with LLW v36 pro.
Analogue Blacksheep
837
694
If it is too long, short of bringing out Mr Dremel, would be curious to see what cooler mods will be produced to address that.
Stifle
47
77
Just measured the inside of my V36pro case and I am hoping to be able to get this card into 182mm ><
Stifle
47
77
The healthy thing to do would be to assume this is not true at all and possibly be pleasantly surprised
Reactions: Snerual
Snerual
174
204
Personally I am only 10% confident this will actually ever become available through official retail channels in Europe and the US.
I think there is a 50% chance this is some prototype that will never be released, and a 40% chance this is some weird China-only semi-custom thing that maybe, just maybe, might surface on TaoBao 6 months from now.
Stifle
47
77
182mm in length
ZS A4DC V3
ZS D2 (D Config)
Lazer3D HT5
Lazer Cravo
J-Hack Pure MK2
Metal Fish S2
Bug C1
Also the V36 pro from LLW Workshop on TaoBao which is similar to the V32 Pro but with a double slot, half-height GPU area, looks like a cut down version of the ZS D2-D. Literally zero clearance
Analogue Blacksheep
837
694
We're going to be in for some very interesting builds in the future. Kind of curious to see if someone ends up making a case that fits this and the HDPLEX 500W unit.
Reactions: Arboreal
Gingerbeer
104
92
Should be doable with the 250W unit too, with a wee bit of undervolting to keep things sensible. Thinking of my 5600G, pulling 65W max, but more like 40-45w under gaming loads.
Reactions: Arboreal
