News Gigabyte/ASUS/GALAX RTX 4060 Low Profile
Gigabyte is creating an RTX 4060 low-profile card: https://www.tomshardware.com/news/g...-be-the-first-low-profile-ada-lovelace-design
3 fans, single 8-pin, 2 slots.
Pie in the sky, but would love to see an RTX 4060ti (or more crazy RTX 4070) model at some point.
___
16/01/2023 Addendum
ASUS now has a 4060 Low Profile card.
188mm, triple fan.
___
19/04/2024 Addendum
Galax has a card
182mm, triple fan, but the PCIE cable is at the front which will affect clearance without a custom solution.
Will advise to look for something slightly bigger
Cases these will fit into (double check before you buy, not everything is available):
Lenovo P3/P360 ULTRA - 182mm* - Gigabyte (May require modding)/Adapter Needed
ZS A4DC V3 - 182mm* - Gigabyte (May require modding)
ZS D2 (D Config) - 182mm - Gigabyte/GALAX (Possible PCIE cable issue)
Gemcase C9 - 182mm - Gigabyte/GALAX (Possible PCIE cable issue)
Lone Industries L5 - 185mm - Gigabyte/GALAX (Consider PCIE adapter)
Custom_Mod SL3 STL 4.8L Rev.1 - 185mm - Gigabyte/GALAX (Consider PCIE adapter)
n3rdware Yocto - 185mm** (Guidance rather than a limit) - Gigabyte/GALAX (Consider PCIE adapter)
n3rdware Yocto+ - 185mm** Guidance rather than a limit) - Gigabyte/GALAX (Consider PCIE adapter)
ZS D2 V2 - 186mm - Gigabyte/GALAX (Consider PCIE adapter)
Custom_Mod Case MINI LP edit. - 190mm - Gigabyte/ASUS/GALAX (Consider PCIE adapter)
J-Hack Pure MK2 - 190mm - Gigabyte/ASUS/GALAX (Consider PCIE adapter)
Lazer3D HT5 - 194mm - Gigabyte/ASUS/GALAX
Lazer3D Cravo - 195mm - Gigabyte/ASUS/GALAX
CAPTAIN CASE V9 - 208mm - Gigabyte/ASUS/GALAX
REVOCCASES N0RDR1 Nano EVO - 210mm - Gigabyte/ASUS/GALAX
Metalfish 2 Plus - 210mm - Gigabyte/ASUS/GALAX
LZmod A24-V5 V2.0 - 220mm- Gigabyte/ASUS/GALAX
Silverstone Milo ML03 - 223mm - Gigabyte/ASUS/GALAX
Silverstone Milo ML04 - 223mm - Gigabyte/ASUS/GALAX
Metalfish G5 - 245mm*** - Gigabyte/ASUS/GALAX (MATX Board width)
Bug C1 - 245mm*** - Gigabyte/ASUS/GALAX (MATX Board width)
SKTC A10 - 245mm*** - Gigabyte/ASUS/GALAX (MATX Board width)
Silverstone Milo ML11 - 272mm - Gigabyte/ASUS/GALAX
Michitaro
Edit: I see you are doing custom fans. 2x80mm should work fine if they hold pressure and you can make a shroud so all the air goes through the fins. I think Noctua makes a 60mm fan? NF-A6x25
Problem with 80mm fans is that they are also blowing air underneath the card (they are much taller than the radiator) I think that's the reason for insufficient air pressure. One fan also extends beyond the radiator (card is not as long as 2x80mm fans combined), but it shouldn't be as negative for the air pressure? I think I am best off with getting those 60mm
721
Reactions: Snerual
Michitaro
To utilize the increased power limit of new bios, I got myself PTM7950 thermal solution + 3x A6x25. While indeed they work better than 2x A8x25, my case has no clearance, and the fans had to be attached by a single screw to the side panel of my A24-V5. I believe because of that the fans are "vibrating" a lot, when put at 60% or more speed. Overall when running at 80-100% the card stays relatively cooler, but the noise and "sound" of it is just unbearable.
What would you recommend in my case? Trying to push some pads between fans and side panel, which will bend the card in pcie slot? Going with some slim 60mm fan (20/15/10 mm). I don't own a 3d printer, nor capabilities to make a custom shroud for such fans. Or maybe just keep card as it is, and run it with 90% PL + UV so temperatures never hit 90 degrees @3500 RPM
Jay85
Scratch that, I've managed to successfully crossflash the quiet VBIOS and overclocked VBIOS from another Gigabyte card.
It's hard to tell how well it works as the RTX4060 power measurement is fairly bogus at best, but with the +13% set in Afterburner HWInfo shows 130W usage at full tilt compared to 115W with the stock LP VBIOS.
But - GREAT NEWS --> FAN STOP / Zero RPM Fan mode WORKS !!
I've also managed a slightly higher TimeSpy Graphics score at 11,705 when paired with the same hardware as before.
Necro'ing this thread because of the post, what did you use in the end to get the bios flashed onto the 4060 LP?
Looking to do the same to increase the power limit and use the fan stop function. Did you just flash the Overclocked VBIOS to get the fan stop working or do both bios's work?
Thanks
721
Successfully flashed the bioss on the 4060 LP, the extra 13% PL overhead is really good! Got a similiar score to SFFMunkee in time spy.
Stock Run:
Overclocked: +125 +1300mem
Bios Flashed: Same settings as SFFMunkee but Mem @1500
Nice work!! I need to go get a fan adapter so I can keep my 0 rpm fan, full speed fan AND higher PL...
Reactions: Jay85
Jay85
I will need to do the same, if you find a good adapter to use let me know please :D.
Gotta admit, even though i've done vbios flashes on older gpu's, it was still abit nerve racking on a 4000 series card since i've never done it on this card or used the new software before with the bypass. The instructions in the github were nice and clear though.
Reactions: SFFMunkee
Snerual
174
204
.... and now Galax has a model as well
Looks quite spiffy with the all-white design but again 182mm long so... impossible to fit in many cases.
Gingerbeer
104
92
182mm long with the power socket right at the end of the board, with no recessing. What a shame, because it looks great.
ondert
344
163
Try 2.5L 😆. PIO JW H610 motherboard from Taobao less than 100 shipped, including superbuy battery removal service. I'm expecting my second one any day. Used Alienware GaN PSU. (Yes room for it inside if desired.)
Sounds like a system will work sensibly good 😅 what’s the case?
milesvw
80
63
This with 8mm standoffs on the lid screws and a little bracket for the GPU corner. Left the second slot Display port covered by the case.
(There is a different "revoccase" that may work with mods: https://smallformfactor.net/forum/t...x-case-optional-1-56l-thunderbolt-egpu.17105/)
