Cooling ETA Prime tests the N3rdware single slot A2000 cooler
ChinStrap
199
178
I have interest in both the RTX A2000 single slot cooler & RTX 4060 LP 170mm cooler. are these custom/one offs, or can you provide some sort of estimate for purchasing?
robbee
n3rdware
863
1,356
The single slot coolers will be available again in 3-4 weeks. The 4060 heatsink is on hold unfortunately, as those single slot coolers are taking all my time.
Reactions: ChinStrap
2,609
2,723
Just watched this, ETA Prime was the perfect guy to review this. Makes me want to run out and buy a Minisforum MS-01 and an A2000. That is a lot of power in a very tiny package. Shout out to @robbee for making a quality product.
robbee
n3rdware
863
1,356
Awesome ! I'll have to keep an eye on your store for availability. I'm wondering if this or the one you made for the RTX 4000 SFF would fit on the recently announced RTX 2000 Ada.
Still trying to figure out wat the PCB of the 2000 Ada looks like. You don't happen to know someone willing to disassemble one? 😁
k0n
218
285
Is it that interesting when the 4060LP exists? Maybe there is something I'm missing... it has a couple fewer cores and only half the L2 cache (12MB).
robbee
n3rdware
863
1,356
The point of these quadro cards in this context is that they can be converted to single slot cards. That won't ever be possible with the 4060LP due to higher TDP, taller caps and stacked IO.
wyrosbp90
I've got a local store selling them at MSRP, was hoping to pick one up if I could find a single slot solution. What would you need?
robbee
n3rdware
863
1,356
Clear high res pictures of the card without cooler. The only thing I figured out by now is that there are some slight differences with the 4000 SFF pcb so this revision of the cooler won't fit yet.
Reactions: wyrosbp90
wyrosbp90
Let me know if there's any other pics you need.
robbee
n3rdware
863
1,356
That’s very helpful, thanks!! Unfortunately, it has some slight differences with the 4000 SFF so the current revision of the single slot cooler won’t fit. I’m already working on a revision that will fit both the 4000 SFF and the 2000 Ada but it will take me some time.
