DAN C4-SFX
k96payne
@dondan, I am new to the SFF game and have been doing lots of research into cases as of late. It didn’t take me very long to discover you! Seeing all of your comments here really shows your dedication towards your work and us customers. I’m pretty much sold on purchasing this case or another case designed by you for my next build. Thanks for all you do!
D90
97
69
Hey Dan sorry to bring this up again, but I was curious if it isn’t too late to consider changing the case to accomodate quad slot gpus..? The 4090 is announced next week and so far all of the aib models leaked appear to use a 4 slot design with only the Founders’ model being a 3 slot.
Reactions: zoso1968
C4_Or_H2O
If you want 4 slot GPU then go for A3?
D90
97
69
I don’t prefer the design as much. Been following the C4 since 2017. But I need upgradability and even if I don’t go with a 4 slot this gen I may be forced to next gen. I don’t prefer to upgrade gpu, psu, AND case with each generation..
cosmichippo
EK and alphacool have listed 4090 water blocks. Curious if the 4090/EK block could fit with a slim 280 rad/fan stackup (36 mm) on the GPU side in traditional layout. Ideally with enough gap to allow decent airflow in between.
dondan
DAN Cases
1,977
8,379
Here is a first research for the new RTX 40x0 Series. The green labeled cards will fit. What do you think should we really increase the C4-SFX again to support this madness?
Name Slots Länge Höhe
Asus RTX 4080 12GB ROG Strix 3.15 336 ???
Asus RTX 4080 12GB TUF 3.25 305 ???
Asus RTX 4080 ROG Strix 3,5 357 150
Asus RTX 4080 TUF 3,65 348 152
Asus RTX 4090 ROG Strix 3,5 357 150
Asus RTX 4090 TUF 3,65 348 152
ColorFul RTX 4090 BattleAx 3 326 140
ColorFul RTX 4090 iGame Vulcan 3,25 340 145
Gainward RTX 4080 Phantom ??? ??? ???
Gainward RTX 4080 Phoenix ? ??? ???
Gainward RTX 4090 Phantom 3.75 329 141.5
GIGABYTE RTX 4090 AORUS MASTER 3.75 358.5 162.8
GIGABYTE RTX 4090 GAMING OC 3.75 340 150
GIGABYTE RTX 4090 WINDFORCE 3.5 331 150
INNO3D RTX 4090 iChill X3 3.25 336 146
INNO3D RTX 4090 X3 OC 3 336 145
KFA2/Galax RTX 4080 12GB Serious Gaming 3 320 138
KFA2/Galax RTX 4080 Serious Gaming 3,5 336 138
KFA2/Galax RTX 4090 Serious Gaming 3,5 336 138
MSI RTX 4080 12GB Gaming Trio 3 ??? ???
MSI RTX 4080 12GB Suprim 3,5 ??? ???
MSI RTX 4080 12GB Ventus X3 2,5 308 120
MSI RTX 4080 Gaming Trio 3,25 337 140
MSI RTX 4080 Suprim 3,75 337 142
MSI RTX 4080 Ventus X3 3 322 136
MSI RTX 4090 Gaming Trio 3,75 337 140
MSI RTX 4090 Suprim 3,75 336 142
Nvidia RTX 4080 FE 2 305 137
Nvidia RTX 4090 FE 3 305 137
Palit RTX 4080 12GB GamePro ??? ??? ???
Palit RTX 4080 12GB GameRock ??? ??? ???
Palit RTX 4080 GameRock ??? ??? ???
Palit RTX 4090 GameRock 3.5 329 137.5
PNY RTX 4080 12GB XLR8 3,5 332 137
PNY RTX 4080 XLR8 3,5 332 137
Zotac RTX 4080 AMP Extreme 3,5 355,5 166
Zotac RTX 4080 Trinity 3,5 356 165
Zotac RTX 4090 AMP Extreme 3,5 355,5 166
Zotac RTX 4090 Trinity 3,5 356 165
Here is a small example.
1) I would never increase the width of the case. With 166mm max GPU height is 148mm.
2) Best case for Slot size would be 3.75 slot.
3) Best case for length would be 360mm but nearly all cards that are over 340mm in length are more than 145mm in height. So 340mm would be sweetspot.
It would require making the case 20mm longer and 10mm increased in height. New dimension:
354x251x166 = 14.8l
With these changes all MSI, INNO3D, COLORFUL cards will fit. Some Gigabyte will fit. But still all ZOTACS and all big ASUS will not fit. So the only real benifit is fitting the MSI cards. What do you think?
Harrar
Name Slots Length Height
Gainward RTX 4080 Phantom 3 ca. 315 ca.137
Gainward RTX 4080 Phoenix 3 ca. 315 ca.137
Gainward RTX 4090 Phantom 3 ca. 315 ca.137
GIGABYTE RTX 4090 AORUS MASTER ca. 4 ca. 350 ca. 160
GIGABYTE RTX 4090 GAMING OC 3.5 ca. 330 ca. 150
GIGABYTE RTX 4090 WINDFORCE ??? ??? ???
MSI RTX 4080 12GB Gaming Trio 3 ca. 330 ca 140
MSI RTX 4080 12GB Suprim 3,5 ca. 340 ca. 140
MSI RTX 4080 12GB Ventus X3 2,5 ca. 305 ca. 140
MSI RTX 4080 Gaming Trio 3,25 ca. 330 ca 140
MSI RTX 4080 Suprim 3,75 ca. 340 ca. 140
MSI RTX 4080 Ventus X3 3 ca. 305 ca. 140
MSI RTX 4090 Gaming Trio 3,75 ca. 330 ca 140
MSI RTX 4090 Suprim 3,75 ca. 340 ca. 140
354x251x166 = 14.8l
Leave as is. The case is perfect. GPU size is insane, as is power use.
Ald0s
Personally I think the case fitting a few 4090s is enough. Not many people are actually going to put one in, as much as we love to talk about limits. The only card I'd be interested in adding compatibility for would be the MSI 4090 Suprim Liquid, and I'm still not sure how it would work. Is it a 3.75 slot card with an additional 240 rad, or is the rad integrated into the 3.75 slots in some kind of jazzy AIO design. If the rad could go up the top and I could use the side slot for the CPU rad (or a big noctua tower) then I'd be stoked.
That being said, I'd be interested to see the thermals of a well laid out fan setup with a C14S and a 4090FE coupled with indirect fan cooling up top. If I could stay air in such a small space without living next to a jet engine, I'd be stoked.
PKDoor
Long time lurker, first time poster here.
After seeing all this GPU monstrosity sizes, I´ve just realised most SFF cases and specially sandwich layout cases are out of the game for the next gen. Not just by GPU Slot or Length limitation, but heat dissipation as well. Also 3+ slots cards render ITX boards pointless, making M-ATX a more sensible choice.
From my utterly ignorant case production knowledge, here are my 2 cents:
1) Keep the C4 as it is and let people cherry pick GPUs that fit the case (Not everyone will buy Top Tier cards)
2) Merging the C4 and A3 into one compact M-ATX case that will fit 99% of all new GPUs and call it a day.
Thank you @dondan for all your updates :)
Reactions: bushonpen
rileycoyote
leave it! we want the case already :-)
354x251x166 = 14.8l
Wyllio
I don't think the size increase makes any sense. NVidia is going in the wrong direction anyways, why follow them? The energy crisis is real here in EU, power draw matters. I personally wouldn't go for these high-end models even if the price or size were more reasonable.
It doesn't make sense but it seems we're in the position where simply going to a smaller node does not provide the same performance gains as it used to and architectural improvements are extremely expensive in the R&D department. Getting close enough and then shooting the chips with tons of power seems like the industry trend to keep those big generational performance increases. At least for the next few years.
