Stalled Custom_MOD MINI
CC Ricers
2,233
2,556
The next generation of Li-Heat risers looks great. What kind of lengths are available for them? I think 20 or 25cm would be ideal for the case.
Test Environment & Equipment:
- GPU: Zotac 1050 Ti Mini
- M/B: MSI H110i Pro
- OS: Win10
- Games: Overwatch
- Benchmark: Catzilla 720p
Results without riser:
- Bus Interface: x16 3.0
- Overwatch, fps: 161
- Catzilla, run #1: 14764
- Catzilla, run #2: 14766
Results with riser:
- Overwatch, fps: 159
- Catzilla, run #1: 14796 (record :))
- Catzilla, run #2: 14718
Verdict: excellent, recommended!
I'm coming in all late about it, but wow, you're getting over 144fps on Overwatch with a 1050Ti? What's your resolution and settings?
Also, your case inspired me to make my own design for a similar case, that will fit a 150-200W internal PSU (Mean Well). I have 1 square foot of metal that I can't really use on anything else but I can use it to make 3 pieces of the case.
Reactions: NRG
sergiiua
CustomMOD
Jan 11, 2017
1,136
2,027
www.custom-mod.com
@CC Ricers interesting case, MeanWell PSU is awesome. Keep us updated ;)
I'll use 300mm LiHeat.
Overwatch settings: 1920x1080, Render Scale = 100%, Texture Quality = High, Dynamic Reflections = Off, all other settings = Low. During the battle I do not notice the difference between these settings and ultra :)
ricochet
SFF AFFLICTED
Oct 20, 2016
547
345
Type D correct? Would this riser work with my Asus Xonar DX LP Sound Card as well or would I need to look at a different version/type?
Reactions: Runamok81
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
Hi I'm Li-Heat Willer Chen
We have updated the cables
Become thinner and softer
Our new cable width is only 57mm in thickness 1.8mm
Rated current:
12V = 2.4A;
3.3V = 1.4 + 0.4A,
(No additional power socket of the graphics card, do not use)
Detailed technical information
http://cryinginthenight68.wixsite.com/liheat
Hi @yawacool,
Are you going to produce powered risers as well ?
You would fill a huge gap on the market since there are only cheap powered PCIe Gen. 2 risers available.
It would be very useful in small builds, equiped with non-PEG GPUs like GTX 1050 Ti.
yawacool
Li-Heat
Feb 1, 2017
80
154
www.liheat.com.tw
Hi @yawacool,
I want to create a new main thread
Avoid occupying discussion here
Affected the main thread
There are questions about you
Reply to you
Please give me some time
I'm asking the administrator @Aibohphobia
How do I set up
alexep7
184
139
Beautiful. Just one question, do you think Zotac's 1050 Ti OC Edition would fit in your case? It says on their website it measures 174mm x 111.15mm, which means it's exactly 1mm longer than your specified max. length...
sergiiua
CustomMOD
Jan 11, 2017
1,136
2,027
www.custom-mod.com
Yay, this case looks awesome man! I'm a sucker for those 45 degree bent pillars at the front of your case, they look sweet! Do you plan to powdercoat the case?
Yes, color will be matte black. But you can choose any color for your case. I'll share photos in a few days.
Boil
1,253
1,094
CustomMOD Mini 3.96L, technical specifications:
  • Volume: 3.96L (220mm x 100mm x 180mm)
  • Material: 2mm Aluminium
  • GPU: length <215mm, height <132mm (Zotac 1080 Mini)
  • CPU Cooler: up to 37mm (Noctua L9i)
  • RAM: up to 37 mm
  • Storage: M.2 only
  • PSU: HDPLEX 300W or Pico-Style DC-ATX
  • Price: $130 (case with PCIe riser)
DEFINITE interest…!!!
Info on how / where internal PSU (assuming HDPLEX NanoATX 160W AC-DC & 300W HiFi DC-ATX combo…?) component(s) fit…?
I would think 300W HiFi DC-ATX next to MB (vertical orientation) & 160W AC-DC (horizontal orientation) under GPU…?
Full-tilt boogie, the following comes in at 350 watts over on PCPartsPicker…
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor
CPU Cooler: Noctua NH-L9i CPU Cooler
Motherboard: Asus ROG STRIX Z270i GAMING Mini ITX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 32GB (2 x 16GB) DDR4-3200 Memory
Storage: Samsung 960 Evo 1TB M.2-2280 PCIe 3.0 x4 NVMe SSD
Video Card: Zotac GeForce GTX 1080 Mini GPU
Reactions: Acalanata
sergiiua
CustomMOD
Jan 11, 2017
1,136
2,027
www.custom-mod.com
@Boil
HDPLEX 160W DC-ATX and HDPLEX 160W AC-DC are not supported.
CustomMOD Mini 3.96L works with HDPLEX HiFi 300W DC-ATX and external power brick. Yes, 300W HiFi DC-ATX is next to MB in vertical orientation.
Your setup without overclocking can easy work with 300W. You need HDPLEX HIFI 300W DC-ATX + Dell 330W DA330PM111 external power brick OR G-Unique unit & G-Unique modded Dell brick (400w version).
