Power Supply Are there cheaper options for 12v PSU then EPP/RPS-200-12 for 150W+?
abrilevskiy
Hello,
Could you please recommend a PSU for eGPU (RTX3050 with TDP 130W)?
Is EPP/RPS-200-12 the best option in terms of quality/price?
Thanks!
BaK
938
938
With quality in mind, you should have a look at digikey or mouser.
And then check on aliexpress if you can get them cheaper, but that's rarely the case.
