It has been 7 months since XPROTO-Mini was released. From then to now, We are cheerful to received recognition from many clients for this product. At the same time, many clients put forward the need for ATX or MATX motherboards to us.
After months of design and multiple rounds of testing, this case called XPROTO-ATX was released in the end.
The ATX case follows the distinctive design of the Mini, such as a butterfly-shaped symmetrical appearance, a triangular structure at the bottom, a cable management space in the middle frame, and a hidden handle.
The volume of case is 16.5L (only refers to the outline of case, and some graphics cards and watercooling will exceed 16.5) , and the IO orientation also conforms to most cases.
SPECIFICATIONS
External Dimensions: 284mm * 170mm * 340mm (L*W*H)
COMPATIBILITY
Motherboards: ATX 305mm*240mm
CPU Cooler Support:240/280 AIO or Air cooling(no limit)
Side AIO bracket: 240/280 AIO
Graphics Card Support:
Riser cable connection: 1 card (no specifications limit)
Direct connection: 2 cards (no specifications limit)
Drive Support: 2.5inchs*3
Power Supply Support: ATX
It can also be modified into a test bench mode.
SPECIFICATIONS
COMPATIBILITY
