Resource icon
.STEP Zotac 2070 Super PCIE Shift Bracket (Testing) 0.9.1
A custom made bracket for the zotac 2070 super. Currently in testing so some dimensions may still be wrong. It may also fit on the 2060 Super. It should shift the 2070S down by 10mm towards the motherboard in the S4M.
This needs taping at the small folding flanges with M3. The folding lines are not indicated so be sure to compare it to your own 2070 Super bracket.
I will update this once someone tests it and makes sure it works.
Contents:
.step
.dwg
.dxf
Clean bracket, bracket with square vents and bracket with triangular vents.
Reactions: edgefull
Author
Steelmint
Downloads
97
Views
3,118
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from Steelmint
Latest updates
  1. Fixed some dimensions.
    I redid the whole bracket and remeasured everything as good as I can on one of my own. The whole...
