NFC Systems S4T eGPU Adapter Assembly
Other NFC Systems S4T eGPU Adapter Assembly 1.0
Contains SolidWorks files, STEP, DXF, and images detailing adapter bracket for an eGPU S4 Tiny setup.
Parts used:
Details:
  1. ADT-Link adapter has a ribbon cable. The heat-shrink on the PCB end needs to be trimmed roughly half, to allow the ribbon to bend up at a 90 degree angle. HANDLE RIBBON WITH CARE, VERY DELICATE.
  2. Transform Bracket should have Thunderbolt porthole milled according to GPUIO specs.
  3. eGPU_Plate, NVME_TB3_Mount, and S4T_Plate DXF files should be cut out of 2mm 5052 H32 Aluminum. Bend UP along all dotted lines. Holes ~ Ø2.5mm need to be tapped M3.
  4. Fasten standoffs to NVME_TB3_Mount using M2x3 screws, then fasten Thunderbolt adapter to standoffs using its own screws, with NVME side facing away from the mount.
  5. Attach S4T_Plate to the chassis, then use M3x4 screws to fasten NVME_TB3_Mount to S4T_Plate.
  6. Plug in PCIE adapter to Thunderbolt adapter.
  7. Fasten eGPU_Plate to S4T_Plate using M3x4 screws.
  8. Attach PCIE adapter to eGPU_Plate using included screws and spacers, while VERY CAREFULLY routing ribbon so that it won't bend awkwardly or interfere with GPU.
Author
hat1324
Downloads
Views
1,675
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from hat1324
