Internal USB 3.0 cable dual
.STEP Internal USB 3.0 cable dual 1.0
Standard internal USB 3.0 19pin or 20pin cable for connecting front panel usb ports to motherboard.
Dimensions are accurate, you can use it for your PC case design and also feel free to use it for your renders. I have measured real unit with digital calipers.
It is mounted to case with two M3 threads.
Author
riba2233
Downloads
Views
1,421
First release
Last update
Rating
0.00 star(s) 0 ratings
