Intel LGA1150 Heatsink Keep-Out Zone
.SKP & .STEP Intel LGA1150 Heatsink Keep-Out Zone 1.0
I took the time to 3D model the Intel LGA115x Heatsink Keep-Out zone according to the dimensions provide by Intel.
What would you use this for?
This is mostly interesting if you are designing you own heatsink or waterblock/Monoblock and want to adhere to the Intel specification to warrant motherboard compatibility.
This model doesn't include the Intel LGA115x Socket en ILM models, but in general this shouldn't pose a problem because these are below the height of the CPU IHS.
The CPU IHS is located 7.781mm ± 0.335 mm from the top of the Motherboard PCB according to Intel. See page 24 of the URL
Integrated Stackup Height (mm) From Top of Board to Top of IHS 7.781 ± 0.335 mm
Page 30 shows the drawing used to model.
Animation of Intel Keep-Out Zone on Gigabyte GA-Q87TN:
ASUS Q87T: You can see the Capacitors just peaking through, ASUS stays within the Keep-Out Zone for motherboard manufacturers.
Reactions: petricor
Author
QinX
Downloads
53
Views
2,127
First release
Last update
Rating
5.00 star(s) 1 ratings
More resources from QinX
Latest reviews
very clear and helpful!
